I need the torque values for the bolts on a 2.7T engine (A6 S4) timing belt change job. ie: waterpump bolts, crank pulley bolts, cam, etc.....Thanks...
These values are from elsawin. If you send me a pm with an email address then I can send you the procedure, I need the engine code to make sure i send you the right info
Tightening torque
Toothed belt sprocket on camshaft
55 Nm
Idler wheel
45 Nm
Toothed belt tensioner
20 Nm
Pulley on crankshaft
20 Nm
10 Nm
Central crankshaft bolt 1)
200 Nm + 180°2)
1) The central bolt should be replaced.
2) 2 times 90°further turning is permitted.
Water pump boltTightening torque: 10 Nm
