Chris NottVolks Autos
    Mo-S3's Avatar
    North West
    706
    a4 i.8 uneven idle
    ive got a 98 A4 1,8 manual and it seems to have a problem idling. If you blip the accelarator it revs as normal but as the revs come down they drop below the normal limit and it feels as thought he car wants to stall. It however doesnt stall but compensates and boosts the revs back up to normal.
    Had the cambelt changed recently and then mot'd and it was running all fine then but just recently this has started happening.
    any ideas what could be causing this?
    Would a faulty coolant sensor cause this problem?
    Scanned it with vag com and just the battery power level came up and also '16500: Engine Coolant Temp.Circ Range/Performance'
    any ideas??
    thanks
    Complete Pleb
    Dec 2006
    East Grinstead
    89
    Could be a coolant thing but not so sure.
    Mine had similar problem. Try checking the throttle valve. Mine was gummed up with oil and crap. Also check the throttle cable tension under idle. Failing that, try checking the MAF.
    I would think it's more to do with the air intake than coolant but you never know, these germans like to keep you on your toes.
    petewon's Avatar
    Dec 2004
    Newcastle
    514
    Yep Id say air intake too, Id try discconection MAF first. That will take 2 seconds to find out if its that or not.
    Pete
    _______________________
    8P A3 2.0 FSI Sport, Leather/Alcantara, Bose, Xenons.
