Chris NottSky Insurance
Results 1 to 10 of 10
    Reidy
    Aug 2006
    GLASGOW
    52
    CV joint removal
    Hi guys ,ive just spent the best part of 3 hours trying to remove the CV joint from my 2001 TT Quattro,does anyone know an easy removal techniques?
    I found a good site showing removal but it seems my car is different from the one shown.
    Any advice would be welcomed! Failing that i will book in with an Audi specialist.All this just to replace two gators with small tears in them! boo hoo
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,857
    I assume you mean remove the joint from the driveshaft, if this is the case then what you will need to do is clean out the grease so you can see inside the joint to open the snap ring that holds the joint onto the shaft, open the snap ring with a snap ring plier and slide the joint off.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Reidy
    Aug 2006
    GLASGOW
    52
    Hi Chris,i had a look and a feel around at the time but couldnt see a snap ring.if its definately there i will have another look only this time ill be armed with a family size tin of degreaser.I was looking for a circlip type attachment as used on vauxhall's etc.Ill have another go tomorrow
    Cheers for your help.
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    904
    you heard it here first........................................
    take the hub bolt that you removed to get the CV seperated from the hub.
    line the CV and drive shaft up in a straight line.
    screw the bolt in untill you feel it touch the end of the drive shaft
    tighten it some more with a wrench
    it'll push on the end of the shaft and pop it out, piece of cake. there's no way as long as i have a hole in my arse you'd ever be able to get to that circlip as it's internal on the shaft and physically impossible to get to.
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Reidy
    Aug 2006
    GLASGOW
    52
    Hi Dave,The method of removal you are describing is the one i previously viewed on the net and is different to the set up on my car.
    My car has a large nut to remove the cv and not a large bolt as you describe.
    shineydave's Avatar
    Jan 2006
    904
    strange, in that case apologies for the hole in my arse comment. in 20 years of Audi and VW ownership i've never come across one with that arrangement
    Dave
    enda1's Avatar
    Jan 2006
    Ireland
    439
    noddy.
    If its an internal circlip the other way is to get a dead blow hammer or a hide (as in leather) mallet. Hold the drive shaft and give the inboard end of the cv joint a good strike and this should pop the cv joint of the shaft (it may take a couple of stikes). Because you have used a soft hammer it will leave no marks on the cv joint
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
    Reidy
    Aug 2006
    GLASGOW
    52
    Thanks guys, but ive given up and booked it in with a mechanic, hopefully sorted soon.I replaced the broken spring and two wishbone bushes so i suppose 3 out of 5 aint that bad.
    cheers.
    Im getting used to the skint knuckles and black finger nails now .
    Mar 2007
    184
    hey dude,
    this might be a bit late but vw/audi/seat cv joints are push on and are held on with a spring washer at the end of the shaft, 2-3 knocks with a rubber hammer get it loose,
    buy yourself a elsawin copy of ebay, my copy covers my a2 and a4
    Complete Pleb
    Dec 2006
    East Grinstead
    89
    If in doubt, give it a clout
