EM TuningChris Nott
    Herby1's Avatar
    VAG All the way
    Oct 2006
    303
    New Suspension kit please help
    hello people,
    i have just ordered a new suspension kit for my audi a3 20v 1999
    could some one please tell me how to change the front shocks, what tools i would need, i know all about spring compression but need urgent help on the shock change.
    thank you so much in advance.
    regards
    chris
    bouncer--daz's Avatar
    A dog is for life....not just for friday nights!
    Mar 2007
    Gloucestershire
    543
    http://www.nclh.org/car/coilover_howto/ best guide ive read online so far
    Daz - Audi A3 - 18" rs4 alloys - Weitec ultra gt 30mm kit - pipercross panel filter - tints all round - facelight rear lights - clear side repeaters - german style plates - flip out dvd touchscreen hu
    Neil_S's Avatar
    Jan 2006
    Hampshire, UK
    248
    I'm going to be installing coilovers on my A4 soon (KW Variant 2s). On the front of the A4 I would need to
    1) Remove the pinch bolt - this is usually in very tight so penetrating liquid and breaker bar required. When the bolt is loose you'll often need a punch and a mallet to punch out the bolt.
    2) Remove the retaining clip in the shock tower (long bent needle nose pliers required)
    3) Remove the three bolts in the engine bay, holding in the shock tower
    4) Remove the bolt holding the lower part of the shock to the suspension
    5) Remove the unit being careful not to catch anything and work on the unit on a workbench (if you need to reuse old bits then you'll need the spring compressors here).
    Usually some good writeups to be found here:
    www.audiworld.com
    www.audizine.com
