Chris NottMonster Motorsport
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    Alarm randomly going off
    Twice recently i've been sitting at home late at night and i've heard my alarm go off. Turned it off and gone outside to check and no one there and nothing different. What's going on?
    I've heard it can be a tactic of car thieves to set ur alarm off repeatedly untill u get fed up and just turn it off when it goes off. But i've tried setting my alarm off before and it's hard to do.
    Built in Germany, Perfected in England
    Jul 2005
    2,488
    sounds more like a buggered sensor. VAG-COM it and see what set the alarm off in each case. If it's the same each time, replace that lock.
    May 2007
    36
    This was happening to my mums car a year or so ago.
    A tip from someone was to spray hairspray over the sensors, this makes them less sensative.
    Never tried it, don't know if it works but i guess it's worth a try
    S6 avant
    Oct 2006
    bewdley Worcestershire
    689
    i had this prob on my 2000 a4 tdi, i read later that the comfort control module is under pass seat and can get full of water. this also causes random operation of the interior lights - which i also had. mine went right as the weather got better but it only played up in the rain.
