JMB RetrofitsChris Nott
Thread: Door Adjustment
    mr_sjc's Avatar
    Aug 2005
    Nottingham, UK
    46
    Talking Door Adjustment
    Hi Guys n Gals,
    Recently my car went in for a spot of repair works after some doofus reversed into the drivers side rear panel which caused a bit of damage to the door. I noticed recently that the bottom of the drivers door seems to be misaligned and doesnt sit flush any more - is there a way I can manually adjust this?
    Cheers Simon
    ________________________________
    A3 1.8 T Sport Java Green 99' S Plate
    Jul 2006
    61
    I tried to do it a bit with mine the alignment was a bit out, there is three screws on the door which i adjusted and the keeper for the lock, i got it a bit better but ended taking it to someone who knows what they are doing he did it in no time and didn,t charge me as he was fitting the bumper back on after some repair garage did that wrong as well. I would take it to someone as it,s not a big job
    Apr 2007
    Surrey
    235
    take it back to wherever it was repaired, they should rectify it for you straight away
    2003 S4 Moro Blue Saloon
