AH FabricationsEM Tuning
Results 1 to 8 of 8
    loafy's Avatar
    Sep 2006
    128
    Audi 1.8T - Non Start?
    Ok 1.8T2004 audi cab, parked her on sat nite and everything was running hungry dorey.
    went to the car last nite and it wont start,it sounds like it trying to start, but not gettingthere at all.
    any ideas? surely if there is a problem with the maf or the coil packs it would still start?
    19's On Route - H&R Springs - RS4 Mirrors - Carbon Fibre Lip - Alpine Sounds + Incar Ipod - Porsche Exhausts - And Other Tricks
    **Coming Soon**
    Jan 2006
    Deal, Kent
    468
    A mate had a coil pack out on his Golf 1.8T, it ran but only on 3, still started etc.
    Mine has done this, but only in the winter when I just started it from cold, moved across the road to outside the house and then left it. Next day it wouldn't go, I thought the worst, but after about 30 secs of trying, it went. Musty have just kind of flooded it with choke on. Never did it again, as I always give it a little rev or take it round the block if i'm only moving it now.
    2001 VW Passat 130 TDi Sport 6 Speed
    1999 Honda CBR900RR-X FIREBLADE
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Maybe your fuel pump is not working properly or the fuel filter is blocked up?
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Jul 2007
    6
    have had coil packs breakdown and blow fuel pump fuse.
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    is the immobilisor light going out on the dash (the one that looks like a key) if the coil in the ignition barrel has packed up it'll start for a second or so then die
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    doeboy's Avatar
    Apr 2006
    Birmingham
    596
    To be fair it could be a whole host of problems. I had a similar problem with my A4 2.8, it turned out to be sparkplugs coated in crap that shell V fuel had "cleaned" out from my tank! Hence she wouldn't start.
    You need a mechanic or someone experienced enough to spend some time on the car to look it over. Better than worrying about it. I've done the same and watched the thread grow with potential problems, and in the end it was the above, which no one would have thought. Ofcourse Im not taking into account known issues, but then they would be quite apparent in the responses.
    "If that's the Turbo Fairy knocking send her round to ShineyDave's"
    shineydave's Avatar
    Jan 2006
    912
    you're right of course, it could be anything from a fuel pump fuse to a broken timing belt although i must admit i take a perverse sort of pleasure from trying to figure out what's gone wrong.
    does this make me strange ? lol
    Dave
    doeboy's Avatar
    Apr 2006
    Birmingham
    596
    depends if the pleasure is salty or not.
