AH FabricationsJMB Retrofits
    Bash_A3's Avatar
    Mar 2007
    Surrey
    233
    Cam belt question on A3 (AUM)
    Hi guys, I've just purchased my Audi A3 (2001) with a AUM engine. It has 76k on the clock & no record of it being done so i'd like to play it safe and get it done early.
    The garage I spoke to this morning recommended the water pump be changed at the same time too as changing one without the other can cause issues. Is there any truth in this? & is 450 a good price for this work?
    Audi A3 2001 1.8T Black - Hyperboost DV, BMC Filter, Kicker 8" Sub in custom Stealth box.
    Manager of the AS fantasy football league "Super Hoops" ... come on you R's!!!
    simonwjones's Avatar
    Aug 2005
    staffs uk
    351
    If you are having the cambelt changed then you definately want the water pumpand tensioners done at the same time. A large cost of the job is labout so you might as well get them done at the same time. If one went later then you just end up paying the same labour cost again for a relatively small parts cost.
    There seems to be a few dealers up here ( Staffordshire ) offering fixed price cambelt changes on Audis. approx 299 for a standard engine and about 350 if i remember for a V6 model.
    Maybe worth while either using this as ammunition at your local dealer or having a day off work and coming up here. I know a few people on here have done just that. Depends really on whether you wnat the dealer stamp or not
    Simon
    A6 3.0TDI Quattro Avant Le Mans
    A6 2.5tdi Quattro Sport 180 Sadly Missed
    A6 1.9tdi Avant ................. Gladly missed
    A6 2.8 Quattro .................. Sadly missed
    Quattro 2.8 Coupe ............. Sadly missed
    SatNav, BT, AMI, DAB
    Bash_A3's Avatar
    Mar 2007
    Surrey
    233
    Thanks for the fast reply, its re-assuring to get some independent advice.
    I'm not too worried about the dealer stamp as the car has mixed history already. I'm assuming the cambelt should be bought from Audi, but the water pump can be bought elsewhere?
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Get the whole lot from GSF car parts. Best by far.
    http://www.gsfcarparts.com/
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    technics100's Avatar
    Feb 2004
    Co Antrim
    775
    I did the pump and belt on my AUM bora, belt was £15, pump was £35 and labour was £85 from local garage.. Get a pump with ametal impellor rather than the standard plastic..
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
