Sky InsuranceBadger5
Thread: KNOCK SENSOR
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    KNOCK SENSOR
    Audi a4 TDI (B6) 1.9 awx engine.
    Any ideas where the knock sensor is located,and if its a fault that would show up on vag-com (sensor advances and retards timing)
    Feb 2007
    22
    Hi vw754
    As far as I know, knock sensors are only fitted to petrol cars, not diesels.
    Cheers Spike
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    the knock sensor is only fitted to petrol engined cars as spike mentioned, and its to detect premature ignition, in one of its many forms. This is not possible with a diesel as the fuel ignites the moment it is injected so it cannot pre-detonate.
    Whats wrong with your engine that would make you want to locate the knock sensor, describe the problem and we'll try and help.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    somebody on this forum said its the knock sensor,ive since found out cars sucking in air! Where andwhat do next?
    Ive done this so far,new filter,new filter seals,new non return valve,new T-piece (fitted on top of fuel filter) all audi parts.
    A4 tdi (b6) 2001 awx engine
