JMB RetrofitsVolks Autos
    HOHN
    Mar 2007
    U.S.A.
    Please Help! I don't know what is going on???
    Hello all.
    I must start out by saying that this site is a great idea.
    Maybe someone can help me. Just this week I installed a brand new alternator and battery on my 1989 200 quattro turbo. Now for some reason the radio, Anti-lock brakes, and (sometimes) headlight dont turn on.
    I checked all the fuses and found only one bad one. I replaced it and the instrument cluster came back on. But the other problems I can't figure out. Would anyone happen to know what I did wrong or what has gone bad?
    Also if anyone is familiar with this year, make, and model; do you have any idea why the diagnostics screen on the instrument cluster works sometimes and not others?
    Hohn
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Hi Hohn that car is rare here now if you go to www.audiworld.com and look up the forums there are plenty of Audi 200 owners there
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    L1 HCS's Avatar
    Candy Tetris Champion, Mahjong Champion, Magic Ball Champion
    Oct 2006
    cymru
    4,597
    Hello & to the site.
    "Swallow your pride occasionally, it's not fattening." - Frank Tyger
    "Avoid making irrevocable decisions while tired or hungry." - Robert Heinlein
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    did you fir the alternator with the battery connected?
    It maybe worthwhile connecting a voltmeter to the battery and see what the voltages are when engine is off (should be about 12.4v) then engine running (around 14v) this will make sure your new alternator is charging correctly.
    A quick way to check your fuses is to use a test lamp, clip one end to earth, then start the engine, on the top of each fuse is a small metal leg either side of the rating ie 15amp.
    try touching each side and if the lamp lights up on one side but not the other, the fuse has gone. this is easier than pulling them out and more reliable.
    The ABS fuse might be under the bonnet, as its normally a high rating, try checking there.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    HOHN
    Mar 2007
    U.S.A.
    THanks a bunch!
    Man, thanks big time for the help. That make too much sense..
    You're great!
