Monster MotorsportVolks Autos
Results 1 to 9 of 9
Thread: oil leak !!!!!
    Jul 2006
    97
    oil leak !!!!!
    hi have seen on my 2.5 that i have a bit of a small oil leak but being as fussy as i am have to do it.So ive just ordered new gaskets for the rocker covers any other gasket i should change now aswell?From reading other posts on this i gather there is a rubber bung on the block and also an engine breather filter can any one tell me more on these items please
    2.5 tdi v6 180 bhp quattro sport mystic blue.18 inch rs8 rims with black between the spokes, audi votex kit, twin chrome scorpion pipes, xennons,heated black buffalo leather sport seats,auto dimming mirrors,serious tailored remap ,ferodo ds 2500 pads front and back upgraded tarrox japan sport competition drilled and grooved discs up front , and ferodo 5.1 racing brake fluid, and about 5k of stereo
    fjtwelve's Avatar
    Jan 2006
    Falmouth, Cornwall
    765
    Mine leaks a bit of oil from the gasket /bung around one of the injectors where it goes through the rocker cover on the offside of the engine. Has done it since i got it, the rubber was originally twisted. I got it fixed at a service but it started to weep again. Has not been a problem other than some oil soaking into the foam on th inside of the plastic engine cover.
    2001 A6 Avant 2.5TDi quattro Sport 180hp+TurboDynamics MD438 hybrid+Bosio Race683s+3" exhaust+Celtic Tuning remap - now with adamss24 replaced with runabout
    2007 BMW 535d AM Sport + Celtic remap
    2004 A4 Avant 1.9TDi quattro Sport 130hp + Superchip - sold & replaced by
    2005 Audi TT 1.8T
    1988 Yamaha FJ1200 120hp finally traded after 23 years for
    1986 Yamaha FJ100 (1300 barrels shhh!) with too many bits to mention
    2011 BMW 320d M Sport son #1
    2004 Suzuki SV650 S son #2
    Feb 2007
    92
    My '99 2.5 V6 leaks too and I'm hoping TC Garage can diagnose the problem next week. I hate having a leaking car.
    I'll post here if they find the source.
    2010 A6 Avant TDI S-Line LeMans
    1999 A6 Avant 2.5 TDI Quattro - gone, not forgotten.
    meatychi's Avatar
    Jan 2005
    UK
    260
    Silicon - it sounds like you have a carbon copy of mine!
    I have a slight leak coming from one of my seals just visibile under the cover!
    1998 A6 Avant 2.5tdi Quattro Tiptronic Sport
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    2.5 tdis are notorious for leaking cam cover gaskets, they normally only leak from the round rubber seal of the o/s head when a cambelt has been done and this has not been replaced, also the excess fuel run of pipes that come off of the injectors tend to become porus after a while recommend replacing these if they look damp, this engine does not really suffer from cam shaft oil seals leaking!
    good luck!
    Jason's Avatar
    Mar 2005
    France
    186
    Mine leaked like a good un,changed rocker cover gaskets,better:changed breather filter:better still,sump gasket,crank shaft oil seal later and the bloody thing still leaked-Gave up
    17
    Mine is leaking - was a little now quite a lot. Audi say it's the upper sump and want 360 to do it ( car is an early A6 2.5tdi (AFB engine))...
    Any tips on fixing this...is it simply a gasket or does it need silicon sealant ?
    Jason's Avatar
    Mar 2005
    France
    186
    Quote Originally Posted by nicknick View Post
    I have the new upper gasket that you can have if you want it (mp me your address).
    The sump is in two bit's, you have to take the first sump off to get at the bolts for the second one.
    Diesel_Seb's Avatar
    Im a Pro Elephant Keeper
    Feb 2009
    Near the Airport.... Bishops Stortford
    52
    Quote Originally Posted by SiliconS View Post
    haha never buy an old beetle then!
    my bug takes 2.5 litres and i had an oil leak and was having to fill it up weekly as it was running out... turns out it had a crack in the crank case, a big long one at that! i have a very stained drive now!
    oh well wouldnt swap it for the world!
    the above information may or may not be true
    Audi A3 1.9tdi (Chipped)
    1967 VW Beetle
