For one it wont fit, you'll need to modify the fitting, and two the wattage is much higher (typically 20w) so it will be much hotter and could set fire to the interior.
You need to check the fuse rating on the circuit. If you put 10W in series with the interior light you are increasing the current draw on the circuit and if the fuse isn't rated for the load it will blow
