EM TuningJMB Retrofits
    silverdragon's Avatar
    Jan 2007
    11
    Oh for the answer to my prayer.
    It seems that my 1995 A4 cabriolet, that has spent more time being laid up than driven, needs a fresh supply of gearbox oil. So, my local garage(trained Landrover) has kindly said he will do the deed. Now, before he cocks this up, are there any special points of note. He understands the oil must be the correct temp and understands he might need to extract it by sucking it out (not by mouth obviously) The car is a 2.6 auto. so would appreciate some help from you boffins.
    Cheers,
    Ray
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    There will invariably be a drain plug on the bottom of the gearbox oil pan, thats a better option than sucking it out.
    Make sure the oil is to Audi spec (buy it yourself) and make sure there isn't a filter on your gearbox, as some have one.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Jan 2007
    11
    Cheers, I have checked with Audi via the VIN number and they say, no filter fitted. Many Thanks, any other tips from anyone would be appreciated.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Get the gearbox hot (by driving it) before draining it.
    When you refill (after you have added some oil), start the engine and cycle it from P to 1 slowly 3 times before you check the oil level. You can check the oil with the engine running. this charges up the torque converter and clutches.
    Chris
    See my images @
    Jan 2007
    11
    Thanks will keep you posted.
    Ray
