Badger5Chris Nott
    axelfols's Avatar
    Jan 2005
    Edinburgh
    124
    Steamy rear window
    I find this time of year my rear window steams up or to be more accurate it is steamy and damp?? After a while it eventually clears but i don't know why this happens. Any ideas appreciated in advance.
    Beerzo's Avatar
    Masa'warty 3200... Talk To Me!
    Feb 2006
    Scotland
    1,241
    There is dampness in the car.
    Can be for loads of reasons. This time of year it rains more so you would be getting in to the car damp and the dampness just gets into the car. You may have a leak somewhere into the cabin. Check that all your carpets and stuff are dry. As you say its the rear window check that there are no leaks in the boot, that maybe getting up through.
    If you can get your hands on some Silica Gel packs and leave them in your car to see if that helps the problem. Note not the wee tiny ones you get with a CD player or something would need to be the size of your wallet or bigger. Check online there should be places that sell them.
    Beerzo's Avatar
    Feb 2006
    Scotland
    1,241
    In A4's it seems to be common for the drain hole under the battery tray to become clogged. this can lead to dampness. Thats another thing you could check.
