AH FabricationsChris Nott
    Jul 2006
    91
    Economy button ?
    What exactly does the "economy button" on the heating system do ?
    In my Seat LCR the economy button simply stopped the compressor working so the air circulating in the car could never be cooler than the outside air temperature.
    It also automatically went into economy mode when it was cold outside.
    Basically you only needed to turn economy off during the summer when the car needed to be cooler.
    A3 2.0T FSI Quattro Sport
    icenutter's Avatar
    Jun 2006
    595
    Does the same on my B5 A5 according to the manual. They've all probably got the same air conditioning system anyway
    enda1's Avatar
    Jan 2006
    Ireland
    439
    Steve-L
    It like you say. When you turn on ecomony it cuts the power to the clutch on the compressor and stops it spinning.
    This disables the aircon circuit and and the system operates like a normal heating system.
    With the clutch disengaged the engine doesn't need to drive the aircon system and the load drops on the engine and it doesn't use as much fuel.
    The hot air is provided by the heater matrix (uses the engine coolant) and cold air is governed by the outside temp
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
    southpaw66's Avatar
    Nov 2006
    UK
    167
    I believe (from another forum) it will also disable to auxilary elec heater in the screen demister. Though never tested that myself.
    A3 Sportback 170TDI quattro S-line
    Lava Grey, SymphonyII, BOSE, Light and Rain Sensor Pack, I-POD connection , MF Steering Wheel, Rear Parking Sensors.
