Badger5EM Tuning
Thread: Stutter
    Nov 2006
    19
    Stutter
    Hi!
    My Passat 1.8T (Free flow pipe, Upsolute chip) has a very slight "stutter" i.e. not enough to be called a misfire under light throttle semi loas citcumstances, plus a reluctance/feeling like it's holding back on a hot day - approx. 30 degrees C.
    Workshop has picked up an error code of the MAF (Mass Airflow Sensor), saying "Low input voltage or something similar.
    He says my MAS is knackered.
    Does anyone know what symptoms one may experience with this problem?
    Many Thanks!
    Nov 2006
    19
    Stutter
    ....oops, meant semi LOAD.
    Jason's Avatar
    Mar 2005
    France
    186
    Try cleaning yeh Maf or buy a new one,If it is that it will be the best 70 you will ever spend on a car!!
    Jason
