Results 1 to 7 of 7
    rich dj's Avatar
    Jul 2006
    UK, Suffolk
    138
    water apears on front mat when it rains hard (A6)
    Audi A6 Avant 2000, water apears on front mat when it rains hard, it is on the near side and seems to be running down the carpet at the front,
    anybody had any problems with this before?
    marmite's Avatar
    Counting the Tesco Club points
    Jul 2006
    Barnet
    1,070
    Morning mate
    Check your plenum chamber may find it is blocked under the battery and the water is coming through the pollen filter.
    Have a look under the battery there is a rubber drain bung which blocks up, reomve it an dclean it out..some people leave it out.
    If it is that cool..
    If not have a look at the plastic frame the pollen filter sits in as this can break were it is bolted to the body there're only cheap from memory.
    Seen front screens leak too...but general it is the above
    good luck
    Audi RS6 Daytona GreyLoving all 455.7BHP of her
    rich dj's Avatar
    Jul 2006
    UK, Suffolk
    138
    Thanks for that i will have a look asap, as i dont want a damp smelling car..
    A6 S line 3.0 Quattro Auto Avant.
    marmite's Avatar
    Jul 2006
    Barnet
    1,070
    Make sure you lift the carpet and check under neath as this could be very wet and your CDL control unit is under there and you don't really want to get that wet.
    rich dj's Avatar
    Jul 2006
    UK, Suffolk
    138
    thanks, sounds expensive
    rich dj's Avatar
    Jul 2006
    UK, Suffolk
    138
    The man was spot on...Thankyou nice one..
    ...Lifted the battery out of the lake of water cleaned out the plug and flooded the garage floor, yes that was it, my pollen filter was soaked, i thought it smelled odd when the car stood for a while and also it was solid black not white (now i now where the pollen filter is) so new one ordered £18 from the Euro dudes and £7.50+vat from local trade counter did not bother to ask Audi.
    A note on this should there be a cover over the pollen filter?
    Also one of the clips snapped of as i breathed on it. Yes it did look rather cheaply made.
    Have not had carpet up as yet but been driving on HI on Passenger side to dry off, should have time next couple of days.
    Thanks again mate, my wife wont get wet feet now.
    rich dj's Avatar
    Jul 2006
    UK, Suffolk
    138
    Angry
    Wrong pollen filter supplied new one is about 8mm slimmer and would let in air, shows correct filter in COOPERS filter book, have left old black filter with them to find part....
