Volks AutosMonster Motorsport
Results 1 to 8 of 8
    Cardiff
    25
    Changing rear brake pads (A4 Avant)
    Does anyone know how to push back the piston on the rear brake calipers in order to fit new pads?
    timps's Avatar
    Shakersville
    Oct 2005
    Shakersville (Bury)
    235
    Yes me because of the handbrake you need a tool to rotate the pistons clockwise whilst applying pressure to push them back in.
    Cardiff
    25
    Cheers Timps. Is this one of those jobs you can do by improvising or is the actual tool a must for the job?
    timps's Avatar
    Shakersville
    Oct 2005
    Shakersville (Bury)
    235
    I borrowed the tool off my best mate who runs his own garage.
    But he reckoned in the dim and distant past when this type of brake first came out they used to improvise one turning and one pushing then they made their own tool.
    http://www.screwfix.com/app/sfd/cat/...56620&id=71972
    This is the type of tool I used it has a metal disk with lugs that locks into the piston, turning the handle makes the piston turn whilst the screw thread locks the plate against the calliper & applies pressure so you should be able to improvise that.
    Cardiff
    25
    Thanks Timps, I'll have a go at knocking something together.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    If you go to any car spares shop they will have the tool to wind back your piston.
    How to:
    http://www.audiworld.com/tech/wheel139.shtml
    enda1's Avatar
    Jan 2006
    Ireland
    439
    A large g clamp works. As you screw the clamp shut the swivel head allows the piston to rotate and it screws bck into its housing
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
    Nov 2006
    19
    I have a Passat (with the same system....)...I used a pair of needle-nose or long-nosed pliers...just be careful not to slip and tear the dust cover.
    To get things started as the piston may be tight, use a c-clamp.
    Quote Originally Posted by NickB
