Sky InsuranceJMB Retrofits
    petewon's Avatar
    Dec 2004
    Newcastle
    514
    maf torx screwdriver
    Right this isnt realy audi specific but Im getting a maf error on my A4 and decided to try and clean it myself anyways Ive stumbled at the first block. The sensor seems to be fitted in with a Torx style bolt but it only has 5 points, not the usual 6, it also has a security hole in the middle of the pattern. Does anyone know what this type of screwdriver is called or where I can get one in the UK?
    Thanks for the help.
    Pete.
    Mo-S3's Avatar
    North West
    706
    Security torx is what they are known as. You can buy a set of these from Halfrauds for about 10. IIRC it should be a T20
    petewon's Avatar
    Dec 2004
    Newcastle
    514
    Excelent cheers, I was having a bit difficulty finding them online Ill just pop to the local halfords. I take it t20 means what size I would need?
    Thanks again.
    Pete.
    Mo-S3's Avatar
    North West
    706
    Yep thats right. the ones i have seen are in a kit fitted to a rail. Silverline tools i think at 9.99
