Results 1 to 9 of 9
Thread: Cat Block
    Surrey, UK
    85
    Cat Block
    Anyone had experience of a blocked cat?
    What are the symptoms?
    mramage's Avatar
    Scotland
    514
    Re: Cat Block
    [ QUOTE ]
    [/ QUOTE ]
    Yes, one of ours ate too much grass once, got quite blocked up.
    [ QUOTE ]
    [/ QUOTE ]
    Usually they're sick all over the place. Best take the cat to the vet.
    Oh, you were talking about cars! [img]/ubbthreads/images/graemlins/lol.gif[/img] [img]/ubbthreads/images/graemlins/angel.gif[/img] [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Feb 2003
    Lincolnshire/Bournemouth
    739
    Re: Cat Block
    I had one. Symptoms included headaches and hallucinations whilst driving, and very poor performance and fuel economy.
    AndyC's Avatar
    Apr 2003
    Dorset
    717
    Re: Cat Block
    lack of boost pressure
    slow reving engine
    fuel economy poor also....
    why do you think you have this??
    Surrey, UK
    85
    Re: Cat Block
    I'm still trying to work out why my engine is unwilling at low revs. Also the turbo and cat get hot really quickly, although this could be normal???
    mramage's Avatar
    Scotland
    514
    Re: Cat Block
    The 1.8T does warm up pretty quickly compared to other engines I've experienced, so that's probably normal.
    Have you had it tested on VAG-COM? Anyone local to you who can give it a try? Or compared with someone who has a similar car if possible?
    Don't know much about it, but I'd have thought something being blocked would have resulted in it being worse at higher revs? [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    Oct 2003
    Re: Cat Block
    Don't know your model details but early A6's 97-99 did suffer from cat. converter failures causing blockages which resulted in lack of power. Also many have & are still suffering from fauly air mass sensors which gives poor acceleration & general lack of power.
    AndyC's Avatar
    Apr 2003
    Dorset
    717
    Re: Cat Block
    any other reasons apart from MAF and cat that cause lack of power...
    if there is NO cat (hmmm mr. MOT) and new MAF what else....
    coolant temp sensor?
    timing pick up?
    blocked zorst?
    air leak on intake side??
    1,361
    Re: Cat Block
    [ QUOTE ]
    timing pick up?
    blocked zorst?
    [/ QUOTE ]
    Coolant temp sensor would be my favourite.
