Volks AutosMonster Motorsport
Results 1 to 14 of 14
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    Ice warning symbol?
    Can anyone tell me why the ice warning symbol only operates between +5C and -5C?
    Surely ice can and does form below -5C?
    hop2407's Avatar
    Oct 2004
    Derbyshire
    1,408
    Re: Ice warning symbol?
    Didn't know it did Gordon.... News to me.... Is that on all models ?
    audi5e's Avatar
    Jun 2004
    809
    I don't know, my 100 shows the ice symbol on the right between 5 and 0 then on the left between -1 and -5 then dissapears below -5... I was wondering why?
    Aug 2005
    Scotland
    126
    Funny thing about mine is that when temp reads zero degrees it shows +0 [img]/ubbthreads/images/graemlins/confused.gif[/img]
    audi5e's Avatar
    Jun 2004
    809
    Mine will read +0 if the actual temperature is still on the positive side of 0 but not yet close to 0.5 and -0 if the temperature is on the negative side of 0 but not closer to -0.5...
    So does anyone know why the ice warning switches off below -5? Is it because of black ice and when it forms? ie can black ice form below -5?
    davidhodgkinson's Avatar
    lancashire
    198
    My S3 does the same.
    I thought it was not on below -5 as you should know its f***ing cold...
    doeboy's Avatar
    Apr 2006
    Birmingham
    596
    In my manual it's not an "ice" symbol it's referred to as just temperature warning. Cold tyres are not happy tyres after all.
    audi5e's Avatar
    Jun 2004
    809
    [ QUOTE ]
    [/ QUOTE ]
    Probably. I was wondering if they switched it off for South African models because German's can't imagine it getting that cold here.... :-)
    Mine a manual
    Sep 2006
    29
    my 2000 A4 2.5 TDI Quattro did this, as did my 2000 S4, I currently have a 2001 Allroad and it hasn't been that cold yet.
    I think the problem is probably software related where somebody's used a "smaller than" function rather that a "less than" function. The use of signing numbers in software may require a different data type, so maybe this was a limitation of the software toolds available at the time.
    Adam
    Jun 2004
    Callander
    91
    Just to confirm all of my Audis with DIS have been the same including my latest 2004 A4.
    2002 Allroad Tdi TIP Quattro, Merlin Purple + Recaro + HID4U Conversion
    southpaw66's Avatar
    Nov 2006
    UK
    167
    Quote Originally Posted by davidhodgkinson
    I think there is some sense in this comment about how the warning is intended. And that is to warn you of the risk of ice when between 0 and 5 and the -5 is just the tolerance/software programming. At -5 or below the road/weather conditions should make you aware of the risk.
    A3 Sportback 170TDI quattro S-line
    Lava Grey, SymphonyII, BOSE, Light and Rain Sensor Pack, I-POD connection , MF Steering Wheel, Rear Parking Sensors.
    ZeroK66's Avatar
    Jun 2004
    Devon, UK
    246
    Dont think I have seen -5... not sure, so couldnt say. That is really odd?
    Facelift Imola S4 | Custom: K04's, Tubular Manifolds, 3" DPs-> 2.75" Catback | FMIC | H&R Coilovers + ARB's | Brembo 8-Pots | SS + DTS | 503HP/475lbs/ft | 1800W RMS
    Sold: Audi A4 (B5) 2.8 Quattro | Ivory Pearl
    Melted: Corrado - IHI 1.8 20vT: 343BHP
    Dec 2006
    Angus
    7
    I had the Temperature drop to -8 C in Glen Esk last Tuesday. The snow flake symbol on my 2004 A4 disapeared at -6 C.
    I did wonder why the snow flake symbol disapeared.
    benw123's Avatar
    Oct 2004
    Herts, UK
    1,863
    The reason that DIS shows the ice symbol below 5C is because water can remain frozen at 4C. In fact, getting all scientific for a second, around 4C is the temperature at which water can exist in three states, as vapour or gas, a liquid and a solid.
    I think Audi are just being cautious by setting the display at 5C, and because it's a round figure. 4C is probably too precise.
    2004 A3 Sportback 2.0TDI SE, RNS-E Sat Nav SW0650 TMC, 17" Star Alloys, Xenons, DIS, Rear Mats & Sunblind, Alu trim, Ebony Black pearlescent
    2006 Honda Accord EX i-CTDI, Arctic Blue, Leather, Sat Nav, XCarLink
