Sky InsuranceBadger5
    Dec 2005
    london
    196
    misfiring fault, tech help needed - have vagcom fault codes
    hi guys
    i own a 2000 a6 avant 1.8T which has devoloped a misfiring fault. it generally drives on average at 30mph max with my foot to the floor with intermittent bursts of power that last no more than a couple of seconds.
    can anyone help me in locating the problem, i can't afford to give it to audi so will try and replace the relevant parts myself once i know what is causing the problem.....
    i've had suggestions of the maf filter or coil pack that could be causing this but these were suggested before i done the scan... i was able to arrange a vag-com scan today and this is what come back........
    vag com - faults found......
    17544 - Fuel Trim: bank 1 (add) system too rich - P1136
    17536 - Fuel Trim: bank 1 (mult) system too lean - P1128
    16684 - random/multiple cylinder misfirwe detected - P0300
    16685 - cylinder 1 misfire detected - P0301
    16687 - cylinder 3 misfire detected - P0303
    16688 - cylinder 4 misfire detected - P0304
    16686 - cylinder 2 misfire detected - P0302
    17925 - main relay (j271) electrical malfunction - P1517
    18010 - Power Supply Terminal 30: voltage too low - P1602
    18034 - Power train Data Bus: missing message from TCU - P1626
    17834 - EVAP Purge Valve (n80) open circuit - P1426
    i called audi with the details of the main relay fault (17925 - main relay (j271) electrical malfunction - P1517) i thought that replacing this would be as good a place to start but after calling 3 dealers nobody could tell me what relay this is! anyone out there know????
    thanks
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    Re: misfiring fault, tech help needed - have vagcom fault codes
    Found this on another site:
    http://forums.audiworld.com/vag/msgs/7459.phtml
    Have you ever changed the ECU?
    Dec 2005
    london
    196
    thanks
    no never changed the ecu, as far as i know it is original. i bought the car second hand and it was running fine for about 4 months before i started getting problems.
    any suggestions?
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    you say 'i've had suggestions of the maf filter or coil pack that could be causing this' have you checked/changed any of them?? if not unplug the maf and see if it will run any better and see if you can borrow a set of coil packs from any 1.8t audi or vw
    Dec 2005
    london
    196
    i unplugged the maf filter and there was a definate change in performance. seemed that the misfiring had gone and i had more power there but i had rough idling.
    i will order a new maf tomorrow and see what change this makes before i attack the coil plugs
    thanks for all advise so far, will post up findings
    fingers crossed.........
    Oct 2004
    Southampton, England
    86
    it is unlikely all four coil will fail at once and i have never seen an ecu diagnose a coil with it still firing.
    the rest of the faults indicate power loss so would be right to assume coils are also missing power feed.
    summary yes sound like your main power relay, will be in the engine bay, usually housed withing a small 2" sqaure plastic box. have found usually a brocken wire between the relay and the ecu though as apposed to the actual relay.
    HTH
