Results 1 to 9 of 9
Thread: key fob Q
    ribena's Avatar
    Oct 2003
    Lincs
    75
    key fob Q
    blundered into an ebay key fob purchase
    had a good search on here for answers but nothing for my specific question
    made sure all part no's and frequencies were the same, new blank cut at local key place, trundled into stealers who were v.helpful but said sorry we can't code the immobiliser as its once only???
    not heard this one before, is this correct or are they being snotty cos' I did'nt get it from them ?? (they did'nt seem to be)
    if the transponder/immob is once only then fair enough but I'm out of pocket [img]/ubbthreads/images/graemlins/burningmad.gif[/img]
    if not any suggestions??
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Re: key fob Q
    The whole Fob thing did my head in..............was at this myself about a month ago.......I thought the programmed the fob not the immobiliser?
    Anyway i am going down this line much easier....
    http://www.vagparts.com/pages/A4rem.htm
    tonedef's Avatar
    Mar 2006
    Chesterfield
    147
    Re: key fob Q
    [ QUOTE ]
    [/ QUOTE ]
    How far out of pocket? I just bought a new key from the stealer complete, that's about 200 before I realised what i'd done [img]/ubbthreads/images/graemlins/noidea.gif[/img]
    Jul 2005
    2,488
    Re: key fob Q
    Im afraid the dealer is pulling your p.
    the CAR is coded to the KEY, not the other way around.
    they are trying to sting you for a new key.
    i'll try and explain:
    the key you have has a uniqe code. The car's ECU and dashpod is then told (adapted) to accept this key to start the engine.
    There are 4 slots in the memory for unique keys, and they can be overwritten to "forget" lost keys.
    ribena's Avatar
    Oct 2003
    Lincs
    75
    Re: key fob Q
    only 45 for the fob and 10 for cutting the blade
    its in for a cambelt next week so I'll get them to try again
    thx for comments
    ribena's Avatar
    Oct 2003
    Lincs
    75
    Re: key fob Q
    they tried again and as they have been so helpful etc I have no reason to disbelieve they are ' pulling my chain'
    beware ebay purchases
    will have another go at ebay this time with a brand new one but will ask some questions beforehand and not leave feedback until its been coded ???
    Jul 2005
    2,488
    Re: key fob Q
    well, if the part numbers to your key and the key you ebayed are identical, there are only three possibilities.
    1. The key you bought is faulty.
    2. You have already got 4 keys coded to your car, and they dont want to overwrite one of the previous keys.
    3. They don't want to do it full stop.
    coding a key to the car is easy, it's just you require tools and a code that the average customer doesn't have.
    what reason did they give for not being able to do it?
    more reading here: http://www.ross-tech.com/vag-com/cars/index.html under immobilizer section.
    ribena's Avatar
    Oct 2003
    Lincs
    75
    Re: key fob Q
    hhmmmm
    they say the key is faulty
    i believe them tbh they say they tried a couple of times while they did the cambelt and given the level of service and other things they helped me out on I've no reason to think otherwise
    I'm happy to put it down to experience, I've saved hundreds of pounds buying off ebay so I'm still 'up' [img]/ubbthreads/images/graemlins/wink.gif[/img]
    if they say they can't if I get a new one off ebay then that will be different
    anyone any experience of them ??
    Jul 2005
    2,488
    Re: key fob Q
    tbh, buying a key of ebay is risk at the best of times - not only because they might not work, as you found out - but you may be buying a key that has been cloned, and now they know the name and address where the car is kept.
    If buying off ebay, keep an eye out for the audi dealerships who advertise on there...
