Monster MotorsportChris Nott
    Milton Keynes UK
    248
    VAG error code. Please help.
    I have the following error message when I do a VAG scan on the engine module.
    00575 intake manifold pressure.
    17-10 control difference intermittent
    1998 110BHP A4.
    My car only has 50K miles on the clock, the MAF has been replaced as there was a flat spot about a year ago.
    I have read that cleaning the inlet pipes sometimes solves the problem, has anyone got any additional info?
    JIm.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,955
    Re: VAG error code. Please help.
    Inlet manifold is worth cleaning if you get the chance and a easy job for were it is positioned.......you will find it is sooted up and stopping the air flow through,,steep in a bath of petrol/diesel to clean it
    Low mileage for 1998 plate
    Milton Keynes UK
    248
    Rev-Head,
    Thanks for the advise!
    The person who had it before me only did 2K per year, got the car with 7.5K on the clock back in 2002.
    Will gove the manifold a clean when the weather improves.
    Jim.
