AH FabricationsEM Tuning
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,628
    can anyone help?
    Hi,
    Put vag com on my car today and these faults turned up.
    VAG-COM Version: Release 311.2-N
    Chassis Type: 4B - Audi A6 C5
    Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56
    Address 01 -------------------------------------------------------
    Controller: 4B0 907 401 AE
    Component: 2.5l/4VTEDC G400SG D70
    Coding: 01012
    Shop #: WSC 02325
    WAUZZZ4
    No fault code found.
    Address 03 -------------------------------------------------------
    Controller: 3B0 614 111
    Component: ABS/ASR 5.3 FRONT D00
    Coding: 00012
    Shop #: WSC 02325
    Address 08 -------------------------------------------------------
    Controller:
    Note: Excessive Comm Errors
    Skipping Address 15-Airbags
    Address 16 -------------------------------------------------------
    Controller: 4B0 907 487 E
    Component: Lenkradelektronik D04
    Address 17 -------------------------------------------------------
    Controller: 4B0 920 981 B
    Component: C5-KOMBIINSTR. VDO D12
    Coding: 00460
    Shop #: WSC 00001
    WAUZZZ4BZ
    Address 35 -------------------------------------------------------
    Controller: 4B0 962 258 H
    Component: Central Lock/Alarm D33
    Coding: 07886
    Shop #: WSC 02325
    1 Fault Found:
    01366 - Opened Due to Crash Signal
    35-00 - -
    Address 45 -------------------------------------------------------
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 02325
    Address 56 -------------------------------------------------------
    Controller: 4B0 035 186
    Component: Radio 0001
    Coding: 00207
    Shop #: WSC 02324
    1 Fault Found:
    00855 - Connection to CD changer
    49-00 - No Communications
    End -------------------------------------------------------
    addresses 08 & 35 are the faults but canany help me with what they mean???
    Cheers,
    Dan
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    Re: can anyone help?
    08, does you car have airbags? if not it may mean that the limit to connect with the controller was reached, or if you do have then there is some kind of fault with the comm settings/a fault with the controller itself. Since it is a later model A6 I am assuming that is does have airbags?
    35, not too sure, sounds like there is a sensor that will open the doors in the event of an accident???
    Just a guess though.
    Jul 2005
    2,488
    first-up, if you can, try another VAG-COM cable.
    Earlier versions of VAGCOM are supposed to be a mare with airbag modules.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,525
    15 is the airbags, 08 was unable to connect with the controller of that module. It would appear you either have a copy cable or a pc reboot was needed, and as for the other it would appear your car had a prang at some point and the doors had been popped open ( safety feature)
    S4_dan's Avatar
    Jan 2006
    1,628
    hi,
    thanx for responses.
    Full hpi on car when i bought, no prangs, its an ex company and have all service reciepts where even the smallest of scratches was noted each month!
    It does have airbags, never had that fault before not had any warning lights or anything on, but laptop was behaving strangely that day so may have something to do with that?
    Dan
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    08 is refering to the air con ecu, that is its address word number, the fact that you cant read it either means you have manual controls or the cable is faulty on your vag com, the crash signal is either due to an accident or a final control diagnosis on the air bag or central locking system.
    central locking address word is 35.
