Results 1 to 7 of 7
    Mar 2006
    glamorgan,wales
    9
    AUDI A4 FLAT SPOT
    HI. I WOULD LIKE TO THANK THOSE WHO REPIED TO MY LAST QUESTION. HEARS MY NEW ONE, I HAVE A FLAT SPOT BETWEEN 2200 AND 3000 RPM ON MY 1998 AUDI 1.9 TDI 110. I HAVE FITTED A DRAGON PLUG IN BOX (FANTASTIC INCREASE ), BUT THIS FLAT SPOT IS STILL THERE, HAS ANYONE GOT ANY SUGESTIONS.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,954
    Re: AUDI A4 FLAT SPOT
    (Boost leak) mine had the same problem was a split underneath on the rubber joining the inlet manifold to the intercooler
    Did you notice behind you when you get this if there is black smoke coming out from behind you(over fueling)
    Mar 2006
    glamorgan,wales
    9
    Thanks for reply,sorry but did not notice smoke,but I will look out for it.Does this rubber have to be replaced,and is it a DIY job,also where would I get it.
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    air mass meter
    Mar 2006
    glamorgan,wales
    9
    THANKS,WHAT IS A MASS AIR METER,WHERE IS IT.
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,954
    foolish3uk's Avatar
    Aug 2004
    458
    goes onto the airbox after the airfilter and measures the air passing through the pipe so it can calculate air fuel mix etc.....
