JMB RetrofitsAH Fabrications
Like Tree1Likes
  • 1 Post By tintiningram
Thread: led indicators - blown bulb / fast blinking effect a6 avant 1.8T 1998 SE
    Apr 2014
    Southampton
    Has anyone swapped there indicators for led ones and found a better way then putting the load resistor on the standard wiring? as on my old misubishi colt I replaced all my lights for leds and instead of putting the resistor in I used an indicator relay switch from a fto and it got rid of the blown bulb / fast blinking effect
    2 PCS X CANBUS ERROR FREE 1156 PY21W BAU15S 21SMD LED AMBER Offset pins | eBay
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,843
    Quote Originally Posted by tintiningram View Post
    You've posted this in a "General" forum with no make\model\year designation, lighting errors are usually model\year dependent, so you need to be more specific about what car you're talking about because at the moment this could be about any make\model\year car ever produced, and may be why you've had no responses.
    A good idea is to put the basic specs of your car in your signature, so every time you post others can see what it is pertaining to. I also interested in upgrading my indicators to LED's, but your post doesn't make clear if we have similar model's.
    2009 A3 SB 2.0T DSG S line
    Apr 2014
    Southampton
    Done
    Artimus likes this.
  1. anyone tried Led indicator bulbs in their B8's?
    By vw754 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 19th December 2013, 12:04
  2. one indicator not working and its not a blown bulb
    By hoffmanvp3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2013, 15:15
  3. LED Indicator bulbs?
    By locost47 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2010, 22:28
  4. LED number plate bulbs ?
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2007, 14:36
  5. Blown bulb
    By b4rkie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th December 2006, 01:44
