    Feb 2014
    6
    Cabriolet Flat Battery issues
    Hi, does anyone have any tips for this problem...
    55 plate S4 Cabriolet which has been parked up over winter
    Flat battery, no red flashing lights on either door, and doors wont unlock manually with the keys.. keys turn both ways but no response... although the boot will unlock. I have tried attaching a trickle charger to the 12v cigarette lighter adaptor in the boot, but nothing so far...
    Have the keys stopped being recognised by the transponder, or is it just that I need to get some charge to the battery for the central locking to override manually?
    Is there another way to open the bonnet and charge up that way.. obviously cannot access bonnet release as things are..
    all help gratefully received,
    Matt
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,424
    you should beable to open door with key
    that doesnt need any charge in battery to work
    Feb 2014
    6
    you would think so, but it doesnt do anything, turns both ways but nothing happens ..
  1. Central locking/flat battery issue
    By Jonesymk2 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2014, 22:20
  2. Flat battery and electrical drain....HELP!
    By CJA318T in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2007, 09:08
  3. Flat Battery
    By walesa4tdi130 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd November 2007, 19:12
  4. Flat battery again
    By batwad in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2006, 10:14
  5. Flat Battery
    By rraghvani in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2004, 18:30
