Volks AutosEM Tuning
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,147
    Help Needed - Someone with an A3 quattro and VCDS
    I'm helping a friend diagnose a haldex fault on his A3 3.2dsg( or at least trying to!)
    Basically we've changed the pump, pressure sensor and the controller but it's still not showing any pressure in the system, i.e. the pre charge pump isn't working so he has no 4wd at the moment.
    I've run the output test in vcds but nothing works.
    What I would be grateful for is if somebody could go into module 22(AWD) with the engine running and check the values in "the adv measuring" tab
    This is what is showing at the moment
    Address 22: AWD (1K0 907 554 L)
    11:31:36
    13.80 V Voltage (Terminal 30)
    7.0°C Oil Temperature
    0.0 bar Oil Pressure
    0.0 Time Sum of Temp. Overrun
    Engine 1 Engine
    ABS 1 Brake Electronics (J104)
    Instruments 1 Instrument Cluster (J285)
    Steer. ang. 1 Steering Angle Sensor (G85)
    0.0 Engine
    0.0 Brake Electronics (J104)
    0.0 Instrument Cluster (J285)
    0.0 Steering Angle Sensor (G85)
    I know one of the first checks to pre charge the system is an engine speed of 400rpm but according to the data above it's not showing any.
    Car is a 54 plate with only with 34k on the clock so don't expect any major issues tbh
    He's spent over £500 already buying various parts and apart from the Haldex itself I don't think there is anything to change.
    E93 335i
    Previous
    2010 R36 Saloon in Biscay Blue
    2008 Red S3
    2005 A3 3.2 quattro S-line Sportback dsg Avus silver
    2005 A3 3.2 quattro Sport Sportback dsg Black
    Anthony566's Avatar
    Nov 2013
    North East
    454
    I know this might be a stupid thing to say but how much is a diagnostics from Audi going to cost ? it just might be worth paying to avoid any unnecessary spend on parts that are not faulty then with the results replace the relevant item ??
    3.2 Ju's Avatar
    Jul 2007
    Yorkshire
    1,147
    He has all the changeable parts now apart from the unit itself and there's no guarantee that for £120 an hour Audi would sort it tbh especially when they want £900 just for a new controller without fitting!
    Is there nobody that can just check the values?
    E93 335i
    Previous
    2008 Red S3
  1. Audi RS3 Part Number help please - someone with ETKA
    By oneniner in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th October 2013, 21:45
  2. Help from someone with knowledge on the bose sound system please
    By Dan s3 audi in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2013, 20:50
  3. Help needed: someone who has ETKA please.
    By a3_sline_tdi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th December 2010, 22:03
  4. Need someone with VAGCOM.
    By S3 LTN in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st July 2008, 20:44
  5. I might need someone with VAGCOM please!
    By chasdrury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st September 2005, 10:36
