JMB RetrofitsBadger5
Results 1 to 11 of 11
    rs13219's Avatar
    Dec 2005
    Cheshire, England
    112
    Digital speed readout.
    Jul 2005
    2,488
    Re: Digital speed readout.
    doa google or search on here... this works on so few cars now, i'm suprised that people still sell it on ebay..
    rs13219's Avatar
    Dec 2005
    Cheshire, England
    112
    Can't seem to find anything? What models does it work on?
    Oct 2003
    South Wales
    2,942
    The codes can be found here:
    http://www.wak-tt.com/tt/climatecontcodes.htm
    scoTTy's Avatar
    Essex, UK
    1,958
    It works on the previous A3 models, TT, previous Golf, etc. Doesn't work on B6/7 A4's or new A3s.
    rs13219's Avatar
    Dec 2005
    Cheshire, England
    112
    What about b5's? Can using this menu have any negative results?
    Cheers, Rob.
    Oct 2003
    South Wales
    2,942
    [ QUOTE ]
    Cheers, Rob.
    [/ QUOTE ]
    May work.. Give it a try! Nothing to lose!
    You cant do any harm with it! Its read-only...
    rs13219's Avatar
    Dec 2005
    Cheshire, England
    112
    Cheers for the responses will have a look?
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    [ QUOTE ]
    Cheers, Rob.
    [/ QUOTE ]
    It works fine on the B5, I'm always using it when on the go to see what speed I'm actually doing rather than rely on the speedo needle.....
    Also works fine on a '95 A6,as it has an almost identical climate control display.......
    As it is a diagnostic feature IMHO using it can't do any harm.....
    [img]/ubbthreads/images/graemlins/wink.gif[/img]
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,612
    Hi,
    I have just tried this using the climate control in my A6.
    I tried the C1 - System malfunction - displayed as a Diagnostic Trouble Code (DTC),
    the result - 0 37 to which i would presume is the code 03.7??
    However, all the codes listed only go upto xx.4!!
    does anyone know what 03.7 code means if anything?
    Aug 2006
    119
    can you only get a speed reading in knh then?
