Chris NottMonster Motorsport
    Jan 2013
    15
    Vibration on low acceleration and rattle noise on idle
    Hi all,
    so this is relating to my mrs' mk 4 golf tdi 130 6 speed, which is the same as the Audi a3 sport tdi 130. It's developed a bit of a shudder/vibration in low revs pulling away in every gear. As the revs increase it goes away. If I absolutely floor it it's hardly noticeable.
    Also when idle it's got a bit of a rattle/knocking sound and when you put the clutch in its much louder and you can actually feel it through the clutch pedal. Any ideas would be appreciated.
    Dooshbag
    Feb 2012
    Exeter
    15
    Hi mate,
    sounds like either your clutch or flywheel are the cause, not sure if yours is fitted with a dual mass flywheel, these are common to fail and can usually be heard by a loud rattle on idle. A local garage shouldnt take long to pinpoint it. hope this helps
  1. Replies: 9
    Last Post: 23rd May 2013, 12:40
  2. 2.0 tdi DSG rattle noise in P and N.
    By Mikemc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2012, 08:17
  3. vibration when accelerating and suspension underload - video
    By tom barker in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th October 2012, 12:12
  4. Strange noise at low speeds and when idling... please help.
    By matt_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th June 2010, 12:04
  5. Rattleing noise from left and back of car
    By pwnorman in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2004, 21:06
