Chris NottBadger5
    Sep 2013
    No power, can't open car, switch it on, switch on lights etc etc!
    Hi
    We have a much loved A3.....
    The issue is that it appears we have a TOTAL powercut in the car which means we can't switch it on or open it or anything.
    we can open car using key, once in no lights no nothing. I think it might be loose wire as occasionally it helps if you slam the door! Not everytime though.
    took it into a garage but the guy couldn't find anything.
    any advice?
    cheers :-)
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Battery dead or disconnected?
    Surely the garage guy would have checked the battery....
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Dooshbag
    Feb 2012
    Exeter
    15
    Hi,
    What year is your audi? Slamming the door indicates a loose connection somewhere. Start from scratch, main power source is obviously battery so if you can aquire a multimeter, test the battery voltage under load. Next, check the main engine compartment fuses, usually 30amp+ ones. Check how tight your battery pole connections are. If the battery is good, and the fuses and connections tight, follow the black negative lead, it will go to the chassis, make sure this is also clean and tight. If all above are okay, it will need looking at by an automotive electrician. Let us know how you get on. Cheers
  1. Can I tap CD changer outlet for switched radio power supply?
    By alfiejts in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th September 2006, 19:07
  2. How much power can a 2.7T produce?
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th April 2006, 20:01
  3. HU getting power when I open the door
    By Anito in forum In-Car Entertainment
    Last Post: 9th January 2006, 08:28
  4. Any places in birmingham where i can get my car chipped from 1.8T 225
    By lowrider786 in forum TT/TT-S/TT-RS Forum
    Last Post: 9th November 2005, 14:25
  5. where can you post cars for sale?
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2003, 18:30
