S
Scimitar
Guest
Hi, help please!
I recently fitted an MMI 3G+ (Google) unit in my A5 and it works like a dream. ..... except that I am having trouble storing the Text Centre Number. I can enter it (+44778501605 for Vodafone in UK) and it works until I turn the ignition off. When I turn the ignition back on the number has reset to +7 (yes, just +7!).
I've tried getting it to pick up a number from the directory and this is successful, until I turn the ignition off!
All other numbers (mailbox, access codes etc.) save correctly and the whole MMI works faultlessly otherwise. I believe there might be new firmware available for the unit, could this cure the problem?
Does anyone have this unit fitted from new? If so, have you managed to save the number?
Anyone any tips or suggestions, please?
Many thanks.
David.
Many thanks.
David.
