Chris NottMonster Motorsport
Results 1 to 12 of 12
    gidimille's Avatar
    Dec 2005
    UK London
    23
    Cruise control not working
    Hey guys and girls
    My curise control is not working any ideas
    secondly my car did not come with a user manual does any one know where I can download one
    do we have any DIY or idiots guide thingy in this forum
    mikeA2B's Avatar
    Aug 2004
    NW UK
    385
    Re: Cruise control not working
    Have you checked the fuse with the speedometer symbol?
    You may need to have your car checked with vag-com.
    Check out ebay for user manuals.
    HTH
    Mike
    a4sline's Avatar
    Oct 2004
    land of Strongbow
    185
    Did someone say cruise control !!!!
    If it's a B6 and you've got no warning lights coming up, then it's probably the clutch pedal switch (manuals only of course!!)
    If it's not a B6, whatcha got ???
    gidimille's Avatar
    Dec 2005
    UK London
    23
    I have just got my self a 1997 2.8 Quattro
    I found the usermanual it say that nI should have a fuse no 11 although when i checked the fuse box there was no fuse in no 11 and when I tried to put one in I notced that there was no connectors for it .... :~ so I will be taking out the fuse unit tommorrow during day light to see what's going on there will let you know how I got on
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    Without sounding silly, are you sure you have cruise on this vehicle?? As that age car would be Non drive by wire, so that means if its there it's either a retro fit kit or the mechanical/unreliable version
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    [ QUOTE ]
    [/ QUOTE ]
    Gee, now us older Audi's are insulted, mechanical/unreliable indeed! :-))
    Easy enough to see on the older versions, are there controls on the indicator stalk or not?
    Assuming a previous owner did not simply change the stalk, check under the bonnet for the vacuum unit connecting to the throttle body... if it's there, then make sure all the vacuum pipes are connected and not leaking. On an older car it is more likely to be a worn vacuum hose than electrics. Though, of course, electrics would still need to be checked once the vacuum side is considered to be ok...
    Apr 2004
    12,354
    [ QUOTE ]
    [/ QUOTE ]
    [img]/ubbthreads/images/graemlins/angel.gif[/img] Don't worry mate,mine would have the same lovely mechanical sysytem on it, had it been fitted
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Jun 2003
    World of my own
    9,813
    You have to cross check the manual reference with the lid on the fusebox. The manual is generic, and doesn't have all the fuses in the righ place. The lid should be correct for the location.
    gidimille's Avatar
    Dec 2005
    UK London
    23
    Hi guys sorry I posted this here
    http://www.audi-sport.net/ubbthreads...&page=0#352773
    before I found this
    gidimille's Avatar
    Dec 2005
    UK London
    23
    so far this is what i found
    I found my user manual under the steering ... [img]/ubbthreads/images/graemlins/smirk.gif[/img]
    I have read it it says something about a fuse 11 I checked out the fuse box there was no fuse in slot 11 [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img]
    when had a closer look at it I noticed that the fuse contacts were not even in slot 11....... [img]/ubbthreads/images/graemlins/burningmad.gif[/img]
    So I thought probably the contact were loose and have fallen out of the back so I ripped out the under cover fro the steering rack and ripped out the fuse unit there was no hanging wire at the back [img]/ubbthreads/images/graemlins/noidea.gif[/img] [img]/ubbthreads/images/graemlins/noidea.gif[/img]
    No I really do have no [img]/ubbthreads/images/graemlins/noidea.gif[/img]
    help
    gidimille's Avatar
    Dec 2005
    UK London
    23
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    On the indicator it has got the cruise control switches
    about the vaccum unit connecting to the throttle body what does this look like
    Does any one have a 1997 2.8 quattro that has cruise control ????
    the instrument level on the car is quite advance
    [ QUOTE ]
    [/ QUOTE ]
    and I did have a 1996 prelude which is a crappy jap car which had the full works.....
    [img]/ubbthreads/images/graemlins/smirk.gif[/img] [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Jun 2003
    World of my own
    9,813
    I haven't even got electric rear windows on my 97 2.8Q!
