Sky InsuranceChris Nott
    45
    2006 a6 multitronic problem/question
    Having read the countless gearbox issues that seem to affect pre 2006 cars I was wondering if anybody has encountered similar problems to what I'm experiencing? Car was parked overnight on an incline, first thing in the morning started engine, Put in to D, accelerated but there was no drive and car rolled backwards!? Turned off engine, tried again and same thing happened. Third time round and it worked normally and car moved forward! It's like it wasn't in gear or something? No warning lights/flashing symbols etc and the car doesn't suffer juddering etc associated with the typical gearbox problem. Car has full main dealer history and I know the gearbox oil was changed at last service in November 2012 but don't know if this was routine or because of an apparent issue? It is a high mileage car (150k) but with the full history I thought it would be ok?? Ay opinion advice gratefully received..Ta
    Jun 2011
    Great Melton Norfolk
    1,348
    They say gearbox is sealed for life, oil does need changing/checking though. Have you had it scanned at all for fault codes?
    45
    Quote Originally Posted by gen.heinz guderian View Post
    Being put on diagnostics on Wednesday to see if anything shows up but just thought I'd see if anybody else had suffered similar symptoms..
  1. Multitronic Problems - Big Problems!
    By Katherine B in forum General Technical / How To
    Last Post: 8th November 2013, 06:45
  2. multitronic problems
    By imported_richpaddock in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th February 2011, 21:45
  3. Problem questions.. please help?
    By New2Audi in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2007, 00:25
  4. A6 TDi Multitronic problems
    By Maggot in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd May 2007, 09:23
  5. MULTITRONIC PROBLEM - HELP
    By JohnBoy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st September 2004, 10:41
