Volks AutosMonster Motorsport
    Nov 2011
    Bristol
    11
    a4 b6 b pillar crash sensor replacement (help with buying the replacement)
    hi all,
    after getting the airbag light come up constantly i got the car scanned to find the problem 01221 which is the drive side airbag crash sensor.
    my mot is due this month and with the unfortunate timing of a few other large outlays every penny counts so i don't really want to splash out 80 pounds to the stealers for a new sensor.
    ive noticed a lot of sensors on ebay that look exactly the same but vary, very slightly with the orientation of the arrow on the sticker and a letter after the part number.
    i was wondering if any of these would work as a direct replacement even though there are very slight differences on the sticker?
    here is my crash sensor for reference:
    sorry its not the sharpest of pictures! if this was anything else other then the airbag system i would go ahead and give it a go.
    here is a ebay link to a selection of crash sensors that look identical:
    audi crash sensor | eBay
    thanks!
    Mar 2013
    europe
    76
    i have no useful info for you but i think this sensor keeps unlocking my car and when i scan the car it says car opened due to crash maybe this is also what is setting my alarm off too.
    do anybody know how many of these sensors there is in a car, 1 for each airbag?.
    good luck on your MOT, i did a stupid thing last time i had mot, i put supermarket fuel in the car, big mistake it wouldn't pass its emissions test at all!.I then put shell s normal fuel in and passed straight away, never again lol
    Nov 2011
    Bristol
    11
    interesting, i normally put some kind of fuel additive in before i go for my mot. pretty sure there are a lot, almost 1 for every airbag but i could be wrong
    Mar 2013
    europe
    76
    Quote Originally Posted by train050 View Post
    asda fuel it was i think 1.36 a litre was why i went . No need with shell fuels , my car is going to get broken up if it carrys on , its a daily battle to get it move.
    sorry i can't help with your problem man.
    regards
  1. Help with car key replacement button fitting
    By gtvlew in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th May 2013, 14:11
  2. Clutch flywheel replacement.....Help with few Q's guys
    By IFFY_77 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th January 2013, 23:14
  3. Help with buying T Piece
    By darreng1983 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2010, 22:24
  4. Need help with buying an A3
    By luke0380 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th March 2009, 07:21
  5. Need help with buying A4
    By samku in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2004, 13:15
