Badger5Volks Autos
    Mar 2013
    A4 3.0 v6 misfire!!
    Hi there, just after a bit of help here!
    I purchased a 2005 a4 convertible 3.0 v6 (asn engine) from a friend with a suspected head gasket problem, No compression on no.1
    Stripped engine down and found there to be a hole in the side of the piston! Replaced the piston, head gasket and timing belt. Didnt have the timing tools so set engine to tdc using the mark on the crank pully and made my own tools before stripping it.
    After the rebuild, started it up and runs lovely, revs up fine with no codes. As soon as I drive it, it starts to stutter really bad and the engine light flashes. Go and plug it in again and says misfire on 1,2,3. I had the injectors refurbed, all new plugs and new coild on cylinders 1 and 3. Just wondering if anyone has any thoughts that maybe able to help me out a bit here?
    Many thanks
    Olly
    Mar 2010
    Durham NE
    578
    What readings are you getting from the lambda probes, do both banks match each other, what fuel trims do you have?
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
  1. Light throttle misfire
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd November 2005, 09:18
  2. juddering / misfire
    By amb276s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2005, 23:55
  3. 1.8t misfire
    By a3kid in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2005, 11:35
  4. Misfire and Spark Plugs under warranty
    By DuncS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2004, 10:39
  5. Audi 80 2.0i 'Misfires'
    By imported_richcarthy in forum Classic Audi Forum
    Last Post: 15th August 2004, 19:39
