Sky InsuranceChris Nott
    Aug 2010
    Kent
    15
    A4 B6 2.4 V6 Throttle body error.
    Any help would be greatly appreciated.
    The car shut down into limp mode but resets when you turn the engine off (epc and traction control light come on). I had a mate scan it and found many errors, so he reset the errors and drove the car which had only one fault re-occur
    "17579 P1171 Angle Sensor 2 for throttle actuator (g188), Implausible Signal"
    So he sprayed some carb cleaner down the throttle body which clears it up but it keeps popping back every 20 mins or so.
    I dont fancy the £700 + VAT and fitting costs so does anyone have any suggestions or know where i can source a second hand part?
    Many thanks
    Scotty
    Aug 2010
    Kent
    15
    If i have to fit a second hand part will i be able to replace the part with a throttle body from a 3.0 instead of the 2.4?
  1. Throttle body error
    By thadeak in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th November 2006, 23:18
  2. Throttle body adaptor query
    By Oz_83 in forum General Technical / How To
    Last Post: 7th October 2004, 17:22
  3. cleaning throttle body
    By Danielson in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th September 2004, 18:57
  4. Throttle Body
    By imported_Cali in forum General Technical / How To
    Last Post: 22nd July 2004, 22:40
  5. Throttle Body
    By darrenp in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th May 2004, 12:33
