EM TuningChris Nott
    May 2011
    1.8t Engine code AJQ from a 1999 4WD TT, easy swap to fit 1.8t AUQ from 2005 2 WD ???
    Hi,
    My brother in law ran low on oil, so engine swap being planned.
    As tilte, both throttle are drive by wire, should be straignt forward ?
    Thanks in advance
    Andy
    Jul 2007
    London
    3,247
    Nope ! 1.8T early have separate water pump and AC compressor bolts on different side, the 2005 has a cambelt running the water pump and is totally different: separate coils,wide band lambda, totally different engines ! Swap like for like...
    FOR SALE:
  1. What engine code is this from? BWA 009587
    By Ash B in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2012, 08:51
  2. Definitive list of engine codes
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2009, 20:52
  3. A4 Intercooler Differences with engine code
    By Markey in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th August 2005, 16:58
  4. Engine code AMU
    By ANDYTQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2004, 09:02
  5. Engine Code for Polo GTi
    By chuffer in forum Volkswagen and other VAG
    Last Post: 12th October 2004, 12:09
