Chris NottJMB Retrofits
Results 1 to 10 of 10
    concoursneil's Avatar
    Aug 2003
    Plymouth UK
    327
    Sluggish on cold start (occasionally) on A3 turbo
    My friends Y plate A3 Turbo seems to give an intermittent fault on cold start.
    When starting seems as if its missing when you put foot down. If you put foot down in mine in 2nd gear it pics up quickly and smoothly , yet in friends it almost as if wrong fuel in it and it struggles to find full power.
    Dont worry correct fuel is in the tank. [img]/ubbthreads/images/graemlins/smile.gif[/img]
    It does not do it all the time even when cold but just occasionally.
    Its fly by wire not cable.
    It feels like it not firing on all cylinders , but nowhere near that bad , that sort of missing feel tho.
    Hope you understand the prob [img]/ubbthreads/images/graemlins/smirk.gif[/img]
    Any ideas you have would be great help, as when it was taken back to dealers prob never happened and nothing was showing on diagnostics according to them.
    Danielson's Avatar
    Jun 2004
    UK
    704
    Re: Sluggish on cold start (occasionally) on A3 turbo
    sounds like the maf sensor to me...
    Aug 2003
    Plymouth UK
    327
    Thats what i thought , what sort of price are you looking at to replace it
    Jun 2003
    Hythe, Kent
    1,180
    Or could be a lamda sensor.
    MAF is 75 + Vat when you exchange your old one.
    Kev.
    Aug 2003
    Plymouth UK
    327
    Also been looking at lambda possibilities too , as it does seem to be air fuel related, cheers guys second oppions on here always appreciated atleast i seem to be barking up the right tree [img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img]
    The joys of the internet [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Dean_T's Avatar
    May 2004
    West Mids
    523
    sounds a little like the problem i had with my A3 Turbo when i first had it
    when i had my remap done Mike@Jabba knocked back the fuelling by ~4%, problem gone
    i think this can be done on VAG-COM but not sure where though [img]/ubbthreads/images/graemlins/frown.gif[/img]
    FWIW my A3 went back to the dealers 3 or 4 times as well as calling the RAC out to it to try and sort it, neither of them could!
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    sounds like you might have a coil pack gone. or maybe a maf
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    My friends S3 had this problem.
    Scanned with VAGCOM which showed a bad coolant temp sensor. Swapped the sensor and now its fine.
    Worth a look I recon.
    Jul 2005
    2,488
    absolutely, temp sensor first to look at, as you've already diagnosed the problem to only when its cold.
    don't trust an empty fault log either, it may just be reading wrong values that dont trigger a fault.
    recomdos's Avatar
    Feb 2004
    North East
    988
    [ QUOTE ]
    [/ QUOTE ]
    is this dead easy to change? where is it located exactly?
    my vagcom is throwing back engine coolant sensor fault and mentioning lambda sensor.
    more than likely get the garage to fit it all, but I just wanna know how much I should be prepared to pay etc etc.
    cheers
    Rob
