Badger5Sky Insurance
Thread: loss of power
    imported_sandfly
    loss of power
    hi people
    i have recently bought an a6 2.7bi tubrbo quattro and in the past couple of days have noticed a substancial lack of power in the rev range above 3.5 k it is fine below this within reason it just lacks the push from the turbo above 3.5 i haven't had any noise or vibration and the engine still sounds perfect
    the only clue i have is a vag com showed that both banks are running lean would this cause the loss of power as the engine trys to protect itself?
    please help me and my local garage are very stuck and dont want to take it to a stealer
    a4sline's Avatar
    Oct 2004
    land of Strongbow
    185
    Re: loss of power
    Try the pipes coming from the secondary air pump for leaks. Gotta be an air leak if coming up with both banks running lean.
    HTH
