AH FabricationsBadger5
    Dec 2004
    UK
    36
    How do I change bulb on A4 Avant
    I can't seem to find a way of removing the rear lamp cluster on my A4 Avant to change one of the bulbs.
    User manual no good as it tells me to take it to a dealer for them to do it. At 65 p/h that is not an option!
    Can anyone help me please?
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    Re: How do I change bulb on A4 Avant
    1.Locate the single (per side) circles in the trim inside the load area by the rear lamp.
    2.With a small flat screwdriver pop the cap open (it's on a string so you wont lose it)
    3.With a 8mm socket or large phillips unscrew the bolt
    4.The lamp is held at the front edge by some pegs that push into rubber cups in the body. To release pull the lamp out and to the side at the same time (it needs to move back a little while you pull it outwards)
    5.Unclip the plug and bulb holder to remove bulbs
    Dec 2004
    UK
    36
    Sorted.
    Thanks for the advice PeteTDI
