Thread: Copper Washers
    Jan 2011
    Aberdeenshire
    628
    Copper Washers
    I just thought I'd post an old trick for recovering copper washers (such as around fuel lines or injector pipes) after dismantling unions. (As I didn't practise what it preach and had a leak recently.....)
    The copper will have most likely work-hardened, so hang it on some wire - or a crap screwdriver - and then heat it until it glows red.
    Small washers will get hot enough over a lighter, big, heavy washers may need a gas ring (if the Missus lets you!!)
    Then drop it into cold water to anneal it.
    One washer fit for reuse.
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    snapon's Avatar
    Jul 2012
    36
    doesn't dropping it in the cold water make it go brittle due to the rapid change in temperature?
    Jan 2011
    Aberdeenshire
    628
    Quote Originally Posted by snapon View Post
    You're thinking of steel and hardening.
    Copper softens when quenched (I actually think it may also soften if left to air cool - can't remember now) as the crystalline alignment is different - try and bend an old washer, heat and quench, then try again and see the difference. If you bash it a bit with a hammer, it will harden again.
  1. Washer Jet warning sound can you stop it?
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2004, 15:19
  2. washer jets?
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2004, 23:02
  3. S3 rear washer jet problem
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2004, 15:34
  4. S3 Washer Jets
    By ianmack in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2004, 16:01
  5. Headlamp Washers
    By ZAF in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2003, 11:13
