Chris NottAH Fabrications
Results 1 to 8 of 8
    Sep 2012
    Audi A3 1.6 1999 Speedo Issue
    Hi all,
    Newbie here with a speedo issue, After trawling the internet and the forums i thought i would post something looking for help.
    Basically it cut out the other day, took it to my mechanic who said he ran a diagnostic and the gearbox/crank sensor came up which i thought was fine but haven't ordered a part yet but since then the fuel gauge is now playing going all the way down to zero but only when I go round bends. this makes me think tht its not a sensor but a supply issue to the cluster but all the other dials work but there is also the added confusion of the oil sensor also flashing up now and again. I checked with my laptop and vag-com at home i like to do a bit of diy but didnt see any gearbox sensor fault code.
    To wrap up any help would be appreciated with the following:
    1) Does anyone know the login codes for an A3 1.6 1999 so i can do an instrument test using vag-com?
    2) anybody else experienced who had it fixed who can provide advice on how to go about fixing it without changing every sensor known to man?
    Thanks for all your help beforehand!!
    snapon's Avatar
    Jul 2012
    36
    Hi mate in answer to your questions
    1. there is no login required to do an output test on clocks
    you probably have an unregistered or lite version of VCDS
    2. does sound like a dodgy set of clocks given the likelihood of the speedo drive and fuel level sender both going down at the same time
    snapon's Avatar
    Jul 2012
    36
    sorry mate forgot to mention if clocks are fckd a new set needs to be programmed in by main stealer VCDS/VagCom cannot do this
    Apr 2007
    Wirral
    191
    I've got a spare set of dash clocks from an a3 in my garage. As said above they would need to be coded to the car.
    phil miller's Avatar
    Sep 2012
    Devon
    843
    so let me get this right, your speedo doesnt work and now your fuel gauge is playing up? when you turn the wheel does your fuel gauge drop to nothing and the dash beeps at you? if it does check all your fuses, if they are all good you will need to check the wiring loom from the speedo drive up under the battery, its very common for a break in the wire to give the problems you have
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    186
    First of all - what clocks do you have ?? pro or facelift model?? If is facelift model with 1/2 DIS and digital clock then there is a common fault with a speedo.
    Currently not in the country
    snapon's Avatar
    Jul 2012
    36
    Quote Originally Posted by Danio View Post
    Facelift was in 2001 so it's safe to assume they are the earlier type given that the op stated car was a 99 A3
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    186
    No facelift clocks starts appearing on late 99.
    Basically if you have speedo with digital clock on the left then that a facelift model.
  1. Audi A3 1.6 1999 Speedo Issue
    By FMAudia31.6 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2012, 17:35
  2. audi a3 1.8t 1999 key fob module
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2010, 19:56
  3. audi s3 8l 210bhp 1999 remapping
    By hi456 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2010, 11:38
  4. Audi A4 TDI 130....possible clutch issues ?
    By Gooner in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th May 2009, 22:48
  5. audi a3 1.6 2000 speedo not working
    By ity768 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2007, 14:39
