After fitting an Oil Pressure gauge i took it for a quick run to see what pressures i was gettin and decided to double check everything was still tight and not leaking around the T-Piece.
Disaster strikes - T-Piece snaps leaving the thread in the block. How the **** am gettin that out?
Would a tap & dia set work or is that going to make the hole bigger?
What would you suggest i use to get it out Tap & Dia or screw extractor?
Really feel like banging my head off the wall and giving myself a dressing down.
