EM TuningChris Nott
    Feb 2012
    12
    audi a4 injector fault
    hi there new to this forum i am looking at one of my frenids car he has audi a4 140 bhp engine code bre 55 reg .engine has mis fire put code reader on coming up with number 4 injector fault open ciruit.
    phone local audi dealer and there said the engine code is not on recall list. is correct ?
    i decided to remove injector to test it put omhs meter on it and there is a circuit am i testing it correctly ?
    if i replace the injector do i have to adjust the rocker arm nut if so what is the procedure
    any info welcome
    thanks peter
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,464
    Welcome to ASN Peter, you would be better posting this over on the A4 section of the forum, you will get more info and help in there. I hope you enjoy the forum.
  1. VAG reader threw up a injector fault but....
    By JDM82 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd September 2011, 08:11
  2. oil leak injector seals audi a4 2.5 tdi v6
    By eliasuk98 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd March 2011, 22:29
  3. Audi A3 TDI injector
    By Grako in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd April 2010, 12:26
  4. Diesel injector fault
    By ArdupinanAudi in forum Diesel forum
    Last Post: 13th July 2006, 21:11
  5. 1992 Audi S4 stock injector size
    By 92S4 in forum Classic Audi Forum
    Last Post: 11th August 2004, 17:14
