Backdraft MotorsportAMD Technik
    Jan 2012
    Elgin, Scotland
    142
    Post Thanks / Like
    Question XENON FOGLIGHT HID LED BULB
    I am looking at a set of LED foglights having seen an avant with them fitted. looked amazing. DOes anyone know what is meant by 'requires resistors to be fitted to prevent fault code'. I am pretty good at electrical wiring being an ex aircraft electrician. Where are the resistors supposed to be fitted? The supplier just said ask Audi.......Not much help there then...... The kit comes with the correct resistors etc but no instructions.
    Sep 2011
    Sunny Bangor. N.Wales.
    206
    Post Thanks / Like
    google it, there's a few places (around £20)
    2000, A4 2.5Tdi Quattro.
    Tinted, 3600WATTSLoud
    Sep 2011
    206
    Post Thanks / Like
    ..... as for the resistors bit... they're not on the BULB WARNING SYSTEM, so you don't need them, fit away and enjoy matey (post pics too)
    Reload's Avatar
    Jul 2010
    Midlands
    89
    Post Thanks / Like
    Blog Entries
    They were on the bulb warning system on my S3, hence I needed resistors when I did the mod. Different Audis, different electrical systems I suppose
    S3 8P2 Silver, RNS-E, Bluetooth, iPod connection, Adaptive xenons, black styling pack, sunroof, privacy glass
    Mods since owned: GIAC stage 1, K&N panel filter, NGK Iridium plugs, Interior LED lights, 'S3' private plate, FBMFSW, cruise control, Nav-TV iPod interface, LED rear lights, SDS High, Front and rear EBC 3GD discs and Yellowstuff pads.
    Next: Sachs clutch, CAI, Milltek TBE, HPFP, Rev D DV, RS4 Fuel return valve, GIAC K04 Extreme remap (Stage 2+), Lowering springs.
    May 2012
    Post Thanks / Like
    flexible led strip lighting
    led outdoor lighting fixtures
    mini led light bars
  1. Led light problem, snapped the bulb holder and bulb
    By podiopie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th January 2012, 20:33
  2. Replacing rear foglight indicator bulb on dash?
    By barters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th April 2011, 14:26
  3. LED H11 Foglight bulb on 8P3
    By grimp in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th February 2011, 14:00
  4. Led Foglight bulbs - Canbus Question
    By miv in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th January 2011, 19:59
  5. Fog Lights ( Xenon or LED Bulb )
    By ST09 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th November 2009, 14:09
