Badger5JMB Retrofits
Results 1 to 14 of 14
    Feb 2003
    21
    Those f****** b****** DV hose clips... Help!
    Right. So, I'm looking to test my DV, OK? I have a sneaking suspicion that the hesitation I'm getting when the car's under load is a leak developing in the diaphragm, and I want to correct this ASAP. The dealer found no DTCs, and "road tested" it for 2 miles in Beckenham before pronouncing himself unable to find a problem... So I'm taking things into me own hands here. Volkspares can supply me with a new, "N" revision part within 24 hours if needs be, so if I find a problem I can replace the DV.
    Took the engine cover off, there's the DV (which appears to be an "H", hooray. Not), and it's held in place by some really fiendish looking clips. I can see they're one-use only, but no amount of prying with a screwdriver would get the things off. So - 2 questions:
    1: For all you DV-changers out there, how the hell do you get the bloody clips off? I am seriously wondering whether I could just trim the pipes down a bit [img]/ubbthreads/images/graemlins/wink.gif[/img] cos I can't see how on earth you can get the buggers off otherwise!
    2: Can one get hold of replacement clips? I ask, as I can't see how I could get a jubilee clip into the depression on the top of the DV... [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Big ups, and indeed props, to anyone with answers... [img]/ubbthreads/images/graemlins/wink.gif[/img]
    Bucks
    1,038
    Re: Those f****** b****** DV hose clips... Help!
    Sorry mate can't help. I can tell you that the guy from AmD took less than 10 minutes to take my DV out, test it (they pump it and release it and have a machine that measures if it is leaking) and put it in again, so I am sure once you have the technique it should be ok...
    Surprised the dealer couldn't test it the same way !
    AL_B's Avatar
    Warrington, Northwest England
    1,564
    Mr Cain,
    They are a real nightmare to get off. I used a combination of needle-nose pliers, a flat-head screw-driver, and a small electronics screw-driver.
    You've just got to use a combination of the above tools to lever and pull the clip appart.
    If anyone knows a quick and easy method, please tell us.
    Regarding replacement clips, you need a 21-25mm jubilee clip, and a small one, 10-13mm I think. Do a search, I'm sure I've posted the clip sizes in the past.
    Hope this helps.
    AL
    notts
    54
    Hi there
    You can remove the clips with side cutters or snips as used for cutting electrical cables and piano wire. When you have removed the valve you can test its function by sucking on the smallest pipe connection which should open the valve if it is working correctly also if you blow down the same pippe it should shut or remain shut under pressure up to a point. Check if it is opening by feeling for movement via the other two ports. By the way dealers have not got a clue about D/V problems or diagnosis of such problems in my experience.
    Good Luck " Bingo "
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Yep.. as Al says... needle nose pliers and screw driver and quite a bit of patience... they are real little b@stards to get off! I just used jubilee clips to re-attach the new one... got a hyperboost DV not the standard one tho. The clip on the vacuum hose just fited on over the bulge at the end of it...
    Rich
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    bingo said:
    Hi there
    Good Luck " Bingo "
    [/ QUOTE ]
    I totally agree... I took mine to audi and said the DV was faulty... the person on the service desk when i called up said "Whats that?" and surprise surprise, they didnt find a problem... So i changed it for a Hyperboost.
    Rich
    Feb 2003
    21
    [ QUOTE ]
    [/ QUOTE ]
    Not "couldn't", so much as "wouldn't"... Not the most helpful people on Earth IME... [img]/ubbthreads/images/graemlins/piss.gif[/img]
    So - to judge by the replies, brute force and ignorance is the way forward here. Do the AMD guys have a special toolkit for this or something? And did they re-use the original clips, audigirl?
    [img]/ubbthreads/images/graemlins/burningmad.gif[/img]Right. So tinsnips and aggression it is, then...
    Bucks
    1,038
    No, they used new clips...
    Don't think they had special tools - just snipped off the old ones pulled the DV out and clipped in the new ones!
    Feb 2003
    21
    Hmm. So, do the clips have a part number? Where can I find that out?... [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Mo-S3's Avatar
    North West
    706
    Ive never had a problem removing those special clips on my car, Use a wire cutter and try to 'peel' back the clip so it unclips from its 3 lugs and unwind it. Simple !!
    And ive always replaced my clips with originals so to keet it looking OEM and untampered. Ive got a special tool for that and a set of different sized clips.
    Feb 2003
    21
    Mo, feed me data - can I order the replacement clips etc. from vagparts or whoever? Muchos Gracias...
    Mo-S3's Avatar
    North West
    706
    when u remove the clips they have a number printed on them, this is the size of the clip. U can order them from vag parts but make sure u give them a good description of where u removed them from. Oh and they cost pennies.
    Feb 2003
    21
    Top-tastic, thanks... [img]/ubbthreads/images/graemlins/smile.gif[/img]
    AL_B's Avatar
    1,564
    I honestly wouldn't bother with the OEM clips. Bang a jubilee clip on, dealer isn't going to bother.
    AL
