UnicornGNJ
    trevyb's Avatar
    Jan 2012
    Bognor Regis
    7
    Post Thanks / Like
    Brake Sensor Cable Connector Broken
    Hi All,
    Last night in the dark and stormy weather under torch light I changed both the front pads and discs on my A3 (2009). I couldn't wait any longer as a stone had been caught between the pad and discs and removed a huge section of disc on one side.
    When I removed the pads from the front nearside wheel I came across the brake sensor cable and to enable access I removed it from the 'grip' that was holding the connector in place (before disconnecting it from the pad). I used little to no force to do this and it came away very easily but it seemed to snap the plastic around the connector which I can safely say needs replacing. Obviously the pad side of the connector is fine but the 'car side' of it is not.
    My question is, where can I get one, and what is the best way I can replace the connector without 'bodging' it? I used to work in electronics so soldering etc is no problem but I want to make sure I do it properly.
    Any hints / tips?
    Cheers - Trev
    Audi A3 1.9TDIe Sportback (2009)
    trevyb's Avatar
    Jan 2012
    Bognor Regis
    7
    Post Thanks / Like
    All fixed now, I've managed to securely build a 'short' into the connectors in a way that a new plug can be put onto the wiring loom at a later date and tied the pad side of the connector out of the way.
    Cheers - Trev
  1. Bonnet cable broken :(
    By jolly14 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th September 2011, 17:56
  2. Replies: 2
    Last Post: 25th June 2011, 12:13
  3. Replies: 0
    Last Post: 27th January 2011, 17:54
  4. Help!!! Broken Side Light Connector
    By Pabs in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th January 2011, 19:54
  5. Is my diagnostic port broken or my VAG com cable?
    By 0w3n in forum VCDS (formerly VAG-COM) forum
    Last Post: 6th June 2008, 20:01
