EM TuningAH Fabrications
    Shao_khan's Avatar
    Concrete Cow Central
    250
    So what does it actually do
    I have seen loads of discussions on various Audi / VW forums about coil packs failing - what do these things actually do?
    Lancashire
    177
    Re: So what does it actually do
    Theres one coilpack per cylinder, they boost the electrical power to make the plug spark, which ignites the fuel etc..etc. Hope this is fairly accurate [img]/ubbthreads/images/graemlins/crazy.gif[/img].
    When the coilpack fails your engine develops a misfire because you are only running on 3 cylinders ie it runs like a dog. You aren't advised to drive too far, even though the car will run, because it can feck up your catalytic convertor.
    Mine went before Xmas and I drove 15 miles to my dealer, I assume this didn't damage the cat because they didn't say anything when I picked the car up.
    Christian
    South West
    52
    Rather than having one coil and a load of leads plus a distributor, condensor, rotor arm etc.. like on old cars.
    Modern audis effectively have one coil per cylinder which connects directly to the spark plug.
    The ecu triggers them directly when they need to spark.
    These individual coils are potted into packs of two or more (I think they are in twos on the Audi A3, but could be wrong)
    These are referred to as coilpacks
    South East
    13
    Does anyone know if this effects all models, nad is it any particular years that are failing.
    Thanks. [img]/ubbthreads/images/graemlins/confused.gif[/img]
